Old Oct 20, 2011 | 08:27 PM
Daniel454's Avatar
Daniel454
Default Re: HIDs, LEDs, Wind Restrictor, 12V plug & More!
Originally Posted by AlphaTrion
It's the two raised round little side prongs on the metal part of the bulb that go into the socket that are giving me the problem. The prongs are straight across, but the factory bulbs are slightly angled. I can put the bulbs in, but because of the prongs I can't push and turn the bulb to latch it in.
For the front turn signal sockets, I can't even get them to go in the socket at all. Very strange.
Weird, I did just realize I had listed that you needed the 1157 for the turns, instead you need the 1156 so maybe this was mt fault? But whats weird is 1156 is what is needed for turns but 1156 have straight across pins, the 1157 (dual intensity) is what is used for the brake lights and those are the one that should have offset pins....
