Old Oct 31, 2005 | 09:35 PM
chxf's Avatar
chxf
Default Re: Low air pressure light keeps coming on
Originally Posted by BullFrog
The sensors are mounted inside each rim and are of fragile plastic. Maybe you hit a large bump and one came loose and the light is coming on. If it goes out for a while then comes on, you might have a small leak on a tire from a nail or etc...
Thanks for the info. I have the one that is called Limited in US but no sensors and no light.
First I thought yours is that kind of system that works with the traction control. If a tire goes flat (less than 80%) it turns quicker and the system shows 'air pressure'. But if you say that you have sensors inside ...?... Strange the didn't equip with real pressure display.
How do you do when you change the wheels? Like summer/winter? Do you put new sensors or simply swap them?
Thanks
