Old Oct 22, 2011 | 01:45 PM
Rockster's Avatar
Rockster
Default Wind noise, and loose passenger window glass.
I've had my XF for several months now and since I purchased it I've noticed wind noise on the passenger side.
Upon closer examination, I can see that the passenger side window isn't aligned properly like the driver side. When I open the passenger side door, I can put my hand around the glass and lift....when I do this is slides up and slightly rotates from the back until it is in the position it is supposed to be in. The total play is maybe an inch up upward travel and 1/2 inch of rotational travel.
I've seen the TSB for adjusting the window but I'm not sure if that applies here and I'm not crazy about taking the door apart. Any thoughts on this?
Thanks, appreciate any input.
Rockster
