Re: Valve cover leak...
When I did this repair I chased all the treads with steel bolts to clean the threads and used aluminum bolts as the final fasterner. Used no loctite. Let them cure after mounting, just barely tighten them. After they are cured then tighten them down to the torque setting. I repaired mine about 7 -8 months ago ,still working ok.
