Old Oct 23, 2011 | 10:03 PM
SRT6 Gang Member's Avatar
SRT6 Gang Member
THREE 6S
Default Re: Stock SRT6 injector flow numbers
The ECU must add or subtract fuel (short term fuel trim/injector pulse width) to maintain an AFR of 14.7 at all times until you pass some threshold and go into open loop.
If your motor is modded and flowing more air, then the ECU will add fuel to keep a 14.7 AFR. After a while the ECU will apply these corrections to an average, long term fuel trim.
Agreed.
Please see my STFT in the attached file. The 20% spikes coincide with max boost during open loop (problem) and/or when removing my foot from the accelerator, sending AFR into 20 in closed loop (normal).
I'm sure you are right about the WOT AFRs being effected by the injectors but I think nailing down the LTFTs will make the WOT tuning much easier, with less change due to temp/environment.
Since the LTFT is an average of STFT, I'm not sure how tuning would be easier, considering LTFT is a product of STFT. One could always disconnect the neg battery cable to reset LTFT and then begin tuning.
File Type: png
