Originally Posted by mwmilk
went to dealer for oil change, replace foglight third time, since inspection was up in a couple weeks said go ahead. there is no check engine light on, but i still failed emission inspection. obd code p0410, secondary air injection system. unbelievable! anyone else have this code come up, and what was it? i am not going to let the dealer rob me again. it seems strange that once the car came off the warranty there is a problem. any help is good help, thanks.
I had the very same "Check Engine" light malfunction with the Code P0410 just 2 weeks ago.
I had been tidying up under the hood, and unknowingly caught the hose connection to the " Secondary Air Pump". Just pushed the hose back on and another Forum Member "Magredvet" turned my "Check Engine" light off. Problem solved. The "Secondary Air Pump" is located underhood just to the Drivers side of the radiator. Hose Connection on the bottom. Hope your is just the same problem. Good Luck
