Originally Posted by bionicdriver
sandpaper and clearcoat work way better than the headlight restoration kit
So, were you having problems with the plastic lens fogging Inside
and Outside?
I'm having a totally whacky problem with my headlights since I bought the car 4 years ago. At night, the low-beams are like using flashlights with weak batteries, just awful visibility. After several attempts by the dealer to adjust them, they now put out two, crescent-shaped beams of weak light that hit the ground about 10 feet in front of the car. Dealer says it's as good as it's going to get and it's terrible.
The highbeams are much better, filling the road with a fairly nice light.
I've swapped-out bulbs going with nearly the brightest bulb available at a Pep Boys or O'Reilly's and checked and double-checked the orientation of the bulb base when installed. I've reconditioned the outside of the lenses, as well, to no avail.
Anyone having this problem?
