Old Oct 26, 2011 | 03:39 PM
caddymike85's Avatar
caddymike85
Default Re: Crossfire headlight question
If you are you Sylvania H7 bulbs they have a notch on the plate of the bulb that must fit into the bottom of the headlight socket in order to be seated properly. I know this is the case for Sylvania bulbs but I'm not sure of other manufacturers. There are also some adjustment bolts in the bottom of the headlight housing where it attaches to the body but since your highbeams are correctly pointed that shouldn't be the problem. Good luck.
