Originally Posted by caddymike85
If you are you Sylvania H7 bulbs they have a notch on the plate of the bulb that must fit into the bottom of the headlight socket in order to be seated properly. I know this is the case for Sylvania bulbs but I'm not sure of other manufacturers. There are also some adjustment bolts in the bottom of the headlight housing where it attaches to the body but since your highbeams are correctly pointed that shouldn't be the problem. Good luck.
Thanks, both of you. Sylvania H7's and they do have a dent in the base to align them. It makes no sense,
180, because the high beams seems fine. The white adjusters were adjusted so far by one mechanic that the dealer had to thread the adjstment rod back together inside the assembly as it had come completely undone.
But I will try your suggestion of rotating the bulb with the lights on and see what happens, thanks again.
