Old Oct 26, 2011 | 05:01 PM
JHM2K's Avatar
JHM2K
Default Re: From OEM to AMG, back to OEM... Still no fuel
Originally Posted by MAXIMUSQUO
Hi @ all,
in the case of fuel gauge I have the same problem after replace OEM odo to CLK AMG odo. Everything works fine but the fuel gauge doesn´t work!
After read all instruction about wiring between OEM and AMG odo and spend a couple time with MB Star diagnostic i got it!
There is a point in MB Star diagnostic development mode that you could move the graph from OEM fuel gauge to the graph of AMG odo and it works rigt now. They will fix in main PCM of your engine.
regards V8Max
OMG!!! You are amazing! I will switch back to the AMG gauges now, and try to find someone with STAR that is willing to help!
Vielen Dank Max!!!
