Old Oct 26, 2011 | 10:10 PM
onehundred80
Default Re: Crossfire headlight question
Originally Posted by billie789
Thanks, both of you. Sylvania H7's and they do have a dent in the base to align them. It makes no sense, 180, because the high beams seems fine. The white adjusters were adjusted so far by one mechanic that the dealer had to thread the adjstment rod back together inside the assembly as it had come completely undone.
But I will try your suggestion of rotating the bulb with the lights on and see what happens, thanks again.
I did not say rotate, I said move it around a little. The flat on the low beams is at the bottom and the flat on the high beams is at the top.
I put one of my bulbs in, held it in place and snapped the clip on that holds it. When I turned the lights on the beam was pointing sideways, so without loosening the clip I just jiggled the bulb by grasping the connector and it popped into position.
