Old Oct 27, 2011 | 06:56 AM
MrMoPar's Avatar
MrMoPar
Default Re: Crossfire headlight question
I did not say rotate, I said move it around a little. The flat on the low beams is at the bottom and the flat on the high beams is at the top.
I put one of my bulbs in, held it in place and snapped the clip on that holds it. When I turned the lights on the beam was pointing sideways, so without loosening the clip I just jiggled the bulb by grasping the connector and it popped into position.
I agree with what you said, it is either simply off to one side as you described, or the tab is upside down.
