bad relay
Oct 28, 2011 | 07:46 AM
permalink
onehundred80
Apr 2006
25,432
650
Ontario
Re: bad relay
Quote:
blackpepper
You could be right if it had a built-in power supply. I will try to locate some small files at Lowes and sand paper for some contact cleaning.
Using files and sandpaper are not to be recommended. If it is the contacts that are at fault you should use very fine abrasive cloth and leave a polished surface. These contacts are polished for a reason and you should attempt to do the same. Leaving a rough spot means you will be doing it again too soon.
If you have a rough surface the spark can arc across any rough high spot and pit that area, a smooth
and polished surface is less prone to pitting.
onehundred80
View Public Profile
Send a private message to onehundred80
Find all posts by onehundred80
