Old Oct 28, 2011 | 10:36 AM
ala_xfire
Default Re: Installed HIDs, Odd Behavior Upon Cold Start - Too Much Initial Power Draw?
Normal OEM wiring, or did you install a relay for the HID's with a large gauge wire directly from the battery to supply the power ?
( I.E. : power the relay/lights from FUSED battery B+, trigger the relay with the normal OEM wiring )
If no relay, you might consider going that route ... ( my 2 cents )
