Re: ignition
OK, I'm not sure why you purchased the new ignition switch. This is not altered by the Sticky Key fix. The cable attached to the ignition switch goes to the gear selector assembly, this cable is attached to it and is rotated 90 degrees to release it. I would look at that end and see if all is well. The instructions to remove the housing is in the Repair Manual, in the Steering section #19 page 19. in the 2004 Repair Manual.
