Old Oct 30, 2011 | 02:05 PM
oledoc2u
Default Re: supercharger lag
2 things could be happening, but need more info. If it is just that little throttle hesitation you don't like, then a "sprint booster" sold by one of our forum members would take care of that. Aren't cheap. SRT SIX is the forum member you need to talk to. The other problem could be the inner cooler pump. This can cause a lack of power, or intermittant power loses. In this case you need a new pump, stock bosch replacement, CM30 Johnson, or a Ford Lightening pump will work as well. Needswings can supply those pumps as well. www.needswings.com More info would help
