Thread: tire rubbing
Old Nov 1, 2011 | 03:19 PM
ala_xfire
Default Re: tire rubbing
Originally Posted by kaiser
I have a 2004 Limited coupe manual 6 spd..approx 43K miles..Just lately I started hearing a rubbing noise whenever I made a right hand turn..turns out the tire is rubbing against the inner wall of the fender. Looks like it is made of plastic etc...When I compared to the driver,s side there is considerable more clearance..Looks like the passenger side is pushing out..like something behind it causing to bulge out..Seems to push in easily with my finger..Just wondered if anyone else has had this happen to their car..and what they did to correct....Thanks in advance...Wayne..
What's behind it is the washer fluid tank .....not good news.
I had that plastic liner off on my roadster to repair the fluid tank ( yea, I'm cheap - didn't buy a replacement tank ).
It is NOT easy to remove the liner - at the bottom rear is a screw that is also involved with the door sill, you have to jack the car up, then support it with stands so you can remove the jack and get to the jack pad.
Long story short - sounds like the fluid tank is having an issue, need to fix that.
