Old Nov 4, 2011 | 07:22 AM
  #478 (permalink)
GraphiteGhost
Default Re: Biggest stereo bang for the buck mod
MrMiata, the two capacitors on each side are creating a non-polorized set. Since this is an A/C sine wave, a non-polorized capacitor is warranted. To make non-polorized caps out of polorized caps, you tie the positives together and splice the negs into the curcuit. The caps values should be the same and the result of tying them together is half the value of the polorized caps used. For example, 560uf polorized caps used makes a set of 280uf non-polorized caps. Use 4 caps to make two sets (one for each side).
Plus, he spent $0.50 cents each capacitor and actual shipping for his mod. Resulting in a bill for only $3.71 (again, thanks for that tip!)
Last edited by GraphiteGhost; Nov 4, 2011 at 07:34 AM. Reason: Correct spelling and added info.
