Re: tire rubbing
Thanks for response...After taking wheel off I noticed the black plastic material was pushed in on the other side causing the plastic behind my tire to push out..causing the tire to rub against it...I pulled plastic back out and heated it up gently with a propane torch and stuck a wrench between it and the axle to reshape and push it back the way it was...so far is good...Again thanks...Wayne
