Originally Posted by FarbenKiber
Anyone remove the stock GPS antenna? I took off what trim i could to see if I could get at it and it doesn't look easy.
I want to eBay my stock navigation system. It seems not including the antenna will hurt its value.
A couple of months ago I installed the factory navigation radio in my crossfire. Just under the dash in the center of the dash on top of the a/c vent tube is where the instructions tell you to install the gps antenna. If this is the same place where it is installed from the factory its not that hard to access. Once you remove all the trim and can access the vent tube just pull down on the top of the vent tube, the flat part of the top will bend down very easy and you can access just above the vent where the antenna is located. My instructions show to install with velcro but I don't know about factory installation. If the factory installation is the same as the after market installation you will find it there.
