Old Nov 9, 2011 | 03:38 AM
RaxCrossfire's Avatar
RaxCrossfire
Default Car & Engine SHAKES
Hello ppl,
I read a bit about these engine shakes and was wondering if you think it could be misfiring or a computer error.
FYI: 1) Car was serviced 1 month ago.
2) No warning lights on the dash
My steering wheel always shook a little bit while stopped, and it always gives a slight rumble when turning off. (All these i consider normal)
The shaking im havin trouble with is a full on, "passenger/driver movement in the car" shakes. The RPM's are average when stopped, however, the needle moves a mm up and drops, and back up n drops (it never did this b4). You can hear it in the engine aswell, like very light revs.
So I popped the hood and saw the engine l physically moving left and right, not aggressively, but noticeable enough. You can see the car shaking from the outside. The shakes only happen when the car is stopped or idle. While driving, the transmission is normal and gear changes r all there.
The shake feels good, kinda like im running a highpowered V8. However, with all positives there is a negative.
I need some advice to locate my negative.
Any help/feedback would be appreciated,
Thanks
Rax
