Re: IC pump replacement
Thanks for ther reply. It is the IC pump that I am after. The problem is getting the fender liner off. I seem to have another piece on mine that your pdf didn't show. It is a horizontal flap up around where you show the leftmost 10mm bolt. The flap runs horizontally into the engine compartment and seems to be attached to the black bolt on the brass bracket shwon in the photos. At least that is what it appears since I can't really see what it is attached to. Maybe if I take the plastic shield off from under the engine I can get a better look. Strange that my fender liner is different from yours.
