Old Nov 9, 2011 | 09:57 PM
Ronman's Avatar
Ronman
Default Left Front Turn Signal Problem
My left front turn signal works and then stops working randomly. There is nothing wrong with the bulb or the fuse.
When I remove the bulb, one of the contacts inside the headlight has a hole in the middle of it. When it is not working, if you touch the turn signal from behind sometimes it will work, so there is bad contact.
Am I basically stuck buying another entire headlight assembly?
There is a socket turn signal part 5174703AA but I assume that is what the bulb goes into and then is put inside the headlight assembly?
Any suggestions would be very very appreciated.
