Old Nov 10, 2011 | 08:12 AM
LantanaTX's Avatar
LantanaTX
Default Re: Help! Please! Odd Noise...grinding/churning?
The most common issue that causes a noise like this is the bearing going out in the idler pulley. Someone also has a similar noise coming from the alternator. If the car is in park/neutral do you hear the noise? If so does the sound change as you increse the RPM's?
