Old Nov 10, 2011 | 12:14 PM
ZAHANMA's Avatar
ZAHANMA
Default Re: water and IAT temps.
Jim, this is pretty fantastic.
One thought for you or Rob, is there a potential to place the two heat exchangers almopst parallel to the ground right behind the fog lights to keep the fog lights in place, but still get the necessary air across the heat exchangers. Seeing as right below the fog lights is just mostly an open area (with the exception of the ic pump on passenger side).
Also, any clue as to cost? Even if it is on abuild to order basis.
