Old Nov 11, 2011 | 10:00 AM
jamesknox's Avatar
jamesknox
Default Re: Help! Please! Odd Noise...grinding/churning?
I have never met a water pump I could not replace... That said, you really should first replace that idler pully and then see if the noise goes away. Try the simple inexpensive fix first!
Yes, I am going to certainly do that first. Should the idler pulley be OEM or is it fine to use an aftermarket one?
