Old Nov 11, 2011 | 01:56 PM
Rockster's Avatar
Rockster
Default Re: Advice Sought!!!
Awesome for you! I just joined the family this past August and this is a special group you will be part of. I couldn't imagine owning one without it.
Few tips if you are buying from a dealer:
(1) Tires - if they are close to needing replacement you might want to negotiate their replacement. The rear tires can be pretty costly :-)
(2) Oil Change - ask them to change the oil and watch them put the Mobil 1 oil in. They may say they changed the oil but it is hard to know for sure and why take chances. Also - is costs $70-100ish for the oil and filter and most dealer don't know that so they say yes eagerly ;-)
(3) Window seals - check for wind noise and have them adjust the windows if needed. It is 100% labor, no parts but a pain in the *** to do yourself
(4) Check for oil seepage around valve covers and breathers. It is common, and isn't horrible. Breathers are easy to fix yourself. Both will scare a dealer into discounting.
Let us know what happens!
Rockster
