4 point Autocross harness
Looking for thoughts and opinions for installing a harness in the Coupe for Autocrossing. I have the SLK/R170 stainless steel roll bar hoops and considering mounting a 4 point harness to it. I'm not certain if I should get the v-type harness (top straps that come together and mount with one hole/bolt on the top), or the standard type that the two top straps are separate and would bolt to each side of the roll bar hoop. Anyone have experience with the v-type? Seems like it might be high and tight on the sides of your neck? This v-type would mean I'd only have to drill one hole on the top instead of one on each side, which I think seems more desirable. Hmmm??
