Old Nov 15, 2011 | 08:00 PM
  #264 (permalink)
LantanaTX's Avatar
LantanaTX
Default Re: Turbo Project about to begin but decision needed
Originally Posted by JHM2K
Another benefit of no FMIC: no need to carve on the core support and neck down the charge pipe to fit. If you recall, on the Needswings, you have to squish a rubber tube through the passenger side. More couplings = more areas for boost to leak. Using a metal pipe would require you to widen the opening.
As for the list:
  • JHM2K
  • LantanaTX
  • (open space to keep Frank on bottom)
  • frankeyser
^^^ Copy and paste into the first post, if you like.
I believe the squished pipe is actaully on the NW DCAI on the drivers side. On my car I had to remove the plastic inserts that the stock tubes connect to in order to run V8 tubes. The passenger side fit very good but the drivers side was smaller and a pain to get the tube in. the NW intake is pretty big since it only sees suction but the charge pipe for our kit only needs to be about 2.5" in diameter. It does need to neck up to the size of the Throttle body at some point. I don't know what Corky thinks about this but I would prefer it necks up just before it enters the engine compartment.
Thanks for starting the list! I hope guys will jump on board. If you are trully interested and can put down a deposit please let us know. Before a deposit is needed you will be much more informed and have a very good idea of what to expect.
