Old Nov 15, 2011 | 09:08 PM
32krazy!'s Avatar
32krazy!
Default Re: Johnson CM30 = Damaged Intercooler?
Originally Posted by dinasrt
This is what the OP referenced; that when Rob @ Needswings hears about an IC leak, he suspects the addition of a higher pressure aftermarket pump, and that's why he only sells the Bosch. (which is less money BTW). That said; hopefully Rob can add to the discussion.
it this idea of a bigger pump causing i/c failures then all the c32 cars with the meziere pump which is a HUGE pump would have i/c blowing up every were. and it hasnt happened. just my .02 2 yrs on my old 32 and the same pump is on my new 32 without a single failure
