Old Nov 17, 2011 | 05:32 AM
ala_xfire
Default Re: engine runs rough, loses power
Originally Posted by hemibeep
It seemed tight, but i do not trust it without the clip
Can I just buy a new connector and solder into place? Part number?
thanks
Alabama shade tree solution : find ( or construct ) a piece of metal about 1" long with 2 holes in it the size the retainer screw will go through.
Bend it to 90 degrees and bolt the CPS on with it under the bolt.
Use a couple of small tie-wraps, one around the wire before the connector, the other through that one and the other hole in the bracket you made.
Voila'
