Old Nov 17, 2011 | 09:39 AM
LantanaTX's Avatar
LantanaTX
Default Re: Question on AMG Wheels
Originally Posted by JHM2K
Various AMG wheels will work. If you're not against using spacers, your selection expands greatly. Front fitments whould have a wheel width narrower than 8.5" and an offset between +35mm and +30mm offset. Mine are 8.5" with +32mm offset and the fit is perfect.
Rears can be as wide as 10" as long as your lowering isn't extreme. OEM suspension allows more room for error. Rear offset should be as close to the OEM (+22mm) as possible. Many Mercedes/AMG wheels are 9.5" wide, +35mm in the rear. The new C63 AMG has insanely shallow offsets... +45mm IIRC. +35mm with a 10-15mm hub-centric spacer (eibachs are best) will bring you back to OEM fitment.
The only rear AMG wheels that will work without spacers are SL and CL fitment... CLS *MIGHT* fit... these are +25 offset and normally 9.5" wide. SL63 wheels are gorgeous and are 19x9.5" with +25mm offset.
Majority of other AMG wheels are shallower offset (>+35mm)
One other thing to keep in mind, is the bolt size. Some of the bigger Benzes use 14mm wheel studs, while we use 12mm. Replicas normally cure this issue, as they will make SL reps in a 12mm bolt fitment. Be sure to check and see if they use ball-seat lugs as well, otherwise you'll need new lugs.
My Mandrus wheels are built exclusively for Mercedes cars, and they utilize a 12mm cone-seat lug bolt.
I am running SL550 wheels. I may be wrong but I thought the rear wheel offset was +17. Most MB wheels don't need a front spacer as our front wheels are very similar to MB wheels. I am 8.5's with 235/40/18 on the front and using 20mm spacers in the rear with 9.5 wide wheels with 265 40 18' tires. And don't even consider the new C class wheels as spacers aren't even available to make these work. My wheels are real MB wheels, but my last set was replica. The replicas were very good quality. there are a couple of good sellers of MB replica wheels on Ebay I think the one I bought from in the past was OE Wheels.
