Could it be the BAS/ESP light? That light will come on with a low battery or after a disconnected battery. If so, start the engine, rotate steering wheel lock to lock and it usually goes out.
If it is steering wheel indicator, maybe your telescoping column is not locked.
James
Don't think its the BAS/ESP as that light goes out.
The tune is working though. WOW. took it around the block.
