Re: Belt snapped while driving :?
You need an idler pulley. This part is always in stock at the MB dealer and usually in stock at the Chrysler dealer. I have found it is usually cheaper to buy at the MB dealer. Chrysler charges extra to put a sticker with their part number over the MB number. If you go to the MB dealer, try to find a VIN for a MB with the 320 engine such as SLK320, C320, CLK320, ML320, E320 etc. The first thing the MB dealer will ask is the VIN number to look up parts. Telling them you have a Crossfire will get you no where most of the time. don't forget to ask for the belt as well. Make sure you have the proper torx bit to remove and install the new idler pulley. You need a metric socket and rachet or breaker bar to take the tension off the tensioner. There is a hex like nut next to the tensioner. Turn counter clockwise to to put the new belt on. if you don't know how to put the belt on, download the service manual that is in a stcky on this site. Good luck!
