Old Nov 9, 2005 | 09:52 PM
Cyril Baldwin's Avatar
Cyril Baldwin
Default Re: Still wind noises
Buy this 1/2 inch weather strip from AutoZone or any store that sells weather strips for cars. If you run your fingers behind the rubber insulation of the window pillars you can feel a gap there which is about the same size as the 1/2 inch weather strip. Just insert the 1/2 inch weather strip to fill the space behind the rubber and that will solve your wind noise problem.
You will never get rained on anymore whenever you drive through a brushless car wash. I hope I explained it as simple as I can. Good luck!
