Thread: HID Focus Spot
Old Nov 21, 2011 | 09:48 PM
maxcichon's Avatar
maxcichon
Default Re: HID Focus Spot
If you have an oval beam pattern, it is definitely not seated properly.
You can unclip the clip (?) and rotate/adjust it when the bulb is on-it won't get too hot. This is the easiest way to do it. The correct position is very subtle. It only has to be off a scoshe and it will give you an oval. Try it-it works!
