Old Nov 25, 2011 | 10:19 PM
oledoc2u
Default Re: Part Needed (See Image)
I can't find that info, it was a long while ago since I tried to order it. It is a bulb socket. There is a flat metal piece that runs down the side to the bottom. It will break at the bend in the bottom. I soldered mine to make a connection again. Sometimes you can pry that piece up in the bottom to make contact if it isn't broken. Best I can do. Chrysler never got it in...they may have them now. Just take the piece into the dealer with you.
