Old Nov 26, 2011 | 01:31 PM
Towncrier's Avatar
Towncrier
Default Sylvania Headlight Restoration Review
After researching the subject of headlight restoration products, I ended up with the Sylvania Headlight which I purchased from the local Advance Auto Parts store for $20. The box for the product claims that the restoration project will take less than 30 minutes, but my experience was that it took about 3 hours. I also deviated slightly from the instructions and, in retrospect, could have just as easily followed the enclosed instructions verbatim and had the same result.
The process is simple:
1. Mask off paint surrounding the headlight with the tape provided
2. Spray headlight with activator - let sit 30 seconds - wash off
3. Wet sand with 400 grit sandpaper until the headlights are uniformly hazy
4. Wet sand with 1000 grit sandpaper for 5 minutes (per headlight)
5. Wet sand with 2000 grit sandpaper for 5 minutes
6. Polish with provided polishing compound for 5 minutes
7. Spray headlight with activator again - wash off
8. Remove tape (I waited until the process was complete to do this step)
9. Thouroughly dry headlight
10. Apply UV block clear coat with cloth
I left the tape on until after I applied the UV block clear coat, but it turns out that it was not necessary. What I thought would be the most difficult step turned out to be one of the easiest steps.
I've posted photos of the various steps on Facebook. You should not need an account to view them. The link to the photos is:
https://www.facebook.com/media/set/?...1&l=951d8f9cef
If you have any questions about the process, I'd be glad to answer them. The Sylvania Headlight Restoration Kit comes with a "lifetime warranty". With any luck, I won't need it.
