Originally Posted by frankeyser
No worries and great answer. It is so hard to plan ahead for something that does not even exist yet. I usually like to have all the parts at once so I can do all the work at once. On this I am just going to have to wait until Corky and the team and BEGi have the kit together and numbers posted before I start preparing my upgrade schedule.
The BEGi kit will be a 7lb system, so you should be planning on HP and torque very close to the SRT. The turbo will have some head room left for higher boost, but 7 and maybe 8 will be the limit with the BEGi tuning. A phase two idea which WEB will hopefully prove out, is switching to SRT ECU/Tuning. This approach will allow greater boost primarily because of the ability to pull back timing at higher boost. Until Web get this to work or I get the 55K ECU to work in my car this should be considered a theory, but a damn good one! I believe the SRT ECU has been worth pursuing and mentioned it pages ago on this thread. While it has the potential to solve a ton of issues and work great, it also creates some new issues which need to be sorted out. Mainly some rewiring and fooling a few sensors. I suspect a Eurcharged tune will also be needed to perfect it. I spoke to Jerry at Eurcharged about this idea earlier this year and he thought it was a very sound idea. Web will be using the i/c pump, but for a turbo, Jerry said he could just tune the pump out. Fooling the s/c clutch might be a big resistor. When Importlab switched his SRT to turbo, I was told he had the s/c pulley wired in but strapped to the side of the engine compartment.
