Old Nov 30, 2011 | 07:24 PM
Erichenderson02's Avatar
Erichenderson02
Default Re: HELP!! Increased idle
Originally Posted by Wetherby48
New to forum and have not been able to find my problem on here, hope someone can help. Just purchased a 2006 coupe with six speed trans. runs great but when coming to a stop with clutch pushed in the RPM's will drop normal but then rise back up to 1500 RPM's for about 5 seconds then will drop back down to the low idle about 600. It seems to also be worse as the car warms up. I have already tried the reset by holding gas down for 5 seconds as recommended on here and has not helped. any help would be greatly appreciated. Please help.
Vacuum leak? Is your car 100% stock? Check engine light?
I had this problem when I installed my cold air intake, because I didn't create an air tight seal around the throttle body.
Other than that, not too sure.
-Eric
