Old Dec 7, 2011 | 02:50 PM
ala_xfire
Default Re: Thinking of getting a crossfire but worried
1. How often was the oil and filter changed ?
2. was Mobil1 0-40 always used.
3. how often was the air filter changed ?
4. how often was the cabin filter changed ?
5. was the serpentine belt ever changed ?
6. Check the brake rotors front & rear for discoloration / scaring.
7. check the brake pads.
8 look inside the wheels, if clean then you can be pretty sure you had a caring owner. ( if waxed, then the owner was analy retentive like me )
9. check the wiper blades.
10. look for valve cover oil leaks ( easily remedied )
11. check the plastic pan under the engine for all sorts of leaky things and missing bolts / screws.
12. is the pump in the boot ? is there an unused fix-a-flat bottle ?
13. if roadster, is there a top release tool ?
14. if roadster, check top condition along with rear window bonding.
15. how old is the battery ?
