Old Dec 11, 2011 | 11:02 PM
crossingmatt's Avatar
crossingmatt
Default Re: Heated Seat Failure Cause??
Originally Posted by a12rag
Good question . . . . I have replaced the seats in my car with Cedar color ones . . . kinda thought that the drivers side was not working the same as pass. side. Sure enough, the bottom heaters are not working . . . . . decided to go check the ORIGINAL seats I pulled out of my car - only have 7,200miles (12k km) on them . . . checked the heater elements on both the drivers side and pass side seats. Sure enough, the bottom on the drivers side has an "open" circuit . . . apparently there is a "repair kit" from Chrysler - I have ordered that, and will see what it consists of, then I can determine what is cause. I suspect that it might have something to do with the connection point of the heating element to the cable that then leads to the connector. Perhaps it is not "rugged" enough to withstand the weight placed on it and having the weight moved around when the car is drivern . . . . ?????
I will attempt to post more with pictures, once I get the parts and see what is required.
Cheers
Mark
A12Rag
So what did the kit consist of and what was involved to do the repair ?
