Originally Posted by Web 3.0
I'll post some more on the acronyms later along with the rest of the translation for the coded listings. Also, there IS a way to globally reduce spark via the Ron adjust setting as well as a way to increase the speed limiter, disable the 02 check after the cat etc. Not all tested but there for myself and others to pursue. I expect that some already have and hopefully they will share to prevent a retrace of steps already taken.
Lots of things to see, but beware, don't muck about unless you are ready for some downtime
Once again, I'll post more later as I'm in a rush at the moment but the best is yet to come. I have lots of tips to share on das in general which are again fairly lacking from what I have found to date.
Would be great when you get a chance to post the info. My shop has the developer version but does not speak German and has not done anything with the R170 in developer mode. Now if I had an E55 they are much more familiar with the settings.
