Thread: Dirty coolant?
Old Dec 16, 2011 | 07:33 PM
onehundred80
Default Re: Dirty coolant?
It is very hard to get a good pic at night in the garage. I changed mine out about a month ago but I used full strength, and refuse to use any kind of cleaner in my systems. I suspect you didn't totally rinse all the cleaner out and now you have contaminated your fresh coolant. Unless you drained the engine block, you did not totally drain the entire system thru the bottom of the radiator. With a flashlight I can see all the way to the bottom of my reservoir perfectly clear.
James, you say you used full strength and someone may misinterpret what you mean.
You used 50% full strength antifreeze and added 50% distilled water.
