Re: Project Crossfire - a Rotrex Supercharged Limited!
This is what I have found. If you have any input on edits I will reply and post back to this list with corrections.
SRT-6 ECU – Developer Variant Coding List
0001
German - Dyn. Radumfang Hinterachse, Low Byte, Various Options Listed
English - Dyn. Rear Wheel Size, low byte, - Various Options
0020
German - Dyn. Radumfang Hinterachse, High Byte, Various Options Listed
English - Dyn. Rear Wheel Size, high byte, - Various Options
0030
German - Dyn. Radumfang Vorderachse, Low Byte, Various Options Listed
English - Dyn. Front Wheel Size, low byte, - Various Options
0050
German - Dyn. Radumfang Vorderachse, High Byte, Various Options Listed
English - Dyn. Front Wheel Size, high byte, - Various Options
0100
German - Baureihe - Various Options Listed
English - Series or Model - Various Options
0150
German - Motor/Hubraum - Various Options Listed
English - Engine/Capacity - Various Options
0160
German
- CAN-Teilnehmer, ABC verbaut
- CAN-Teilnehmer, ABC nicht verbaut
English
- CAN-Participants, ABC (Active Body Control) installed
- CAN-Participants, ABC (Active Body Control) is not installed
0162
German
- CAN-Teilnehmer, EGS verbaut
- CAN-Teilnehmer, EGS nicht verbaut
English
- CAN-Participants, EGS - ETC (Electronic Traction Control) installed
- CAN-Participants, EGS - ETC (Electronic Traction Control) is not installed
0164
German
- CAN-Teilnehmer, EWM verbaut
- CAN-Teilnehmer, EWM nicht verbaut
English
- CAN-Participants, EWM - ESM (Electronic Shifter Module) installed
- CAN-Participants, EWM - ESM (Electronic Shifter Module) is not installed
0166
German
- CAN-Teilnehmer, MRM verbaut
- CAN-Teilnehmer, MRM nicht verbaut
English
- CAN-Participants, MRM - SCM (Seat Control Module) installed
- CAN-Participants, MRM - SCM (Seat Control Module) is not installed
0168
German
- CAN-Teilnehmer, Multifunktionslenkrad vorhanden
- CAN-Teilnehmer, Multifunktionslenkrad nicht vorhanden
English
- CAN-participant, Multi-function Steering Wheel Exists
- CAN-participant, Multi-function Steering Wheel Does Not Exist
0170
German
- CAN-Teilnehmer, EZS vorhanden
- CAN-Teilnehmer, EZS nicht vorhanden
English
- CAN nodes, EZS (Electronic Ignition Switch) Exists
- CAN nodes, EZS (Electronic Ignition Switch) Does Not Exist
0172
German
- CAN-Teilnehmer, Luefterdrehzahlvorgabe ueber CAN
- CAN-Teilnehmer, Luefterdrehzahlvorgabe nicht ueber CAN
English
- CAN-Participants, Fan Speed Control is by CAN
- CAN-Participants, Fan Speed Control is not by CAN
0174
German
- CAN-Teilnehmer, EHB vorhanden
- CAN-Teilnehmer, EHB nicht vorhanden
English
- CAN-Participants, EHB - SBC (Electrohydraulic Brake) Exists
- CAN-Participants, EHB - SBC (Electrohydraulic Brake) Does Not Exist
0176
German
- Motor-Code E/A 1, AGR - Diagnose ein
- Motor-Code E/A 1, AGR - Diagnose aus
English
- Engine code I / O 1, AGR (Exhaust Gas Recirculation) - Diagnostics On
- Engine code I / O 1, AGR (Exhaust Gas Recirculation) - Diagnostics Off
0178
German
- Motor-Code E/A 1, SLP - Diagnose ein
- Motor-Code E/A 1, SLP - Diagnose aus
English
- Engine code I / O 1, SLP – Secondary Air Pump (Air Injection) - Diagnostics On
- Engine code I / O 1, SLP – Secondary Air Pump (Air Injection) - Diagnostics Off
0180
German
- Abgasklappe Diagnose ein
- Abgasklappe Diagnose aus
English
- Exhaust Gas Valve - Diagnostics - On
- Exhaust Gas Valve - Diagnostics - Off
0182
German
- Motor-Code E/A 1, LS-hinter KAT - Diagnose ein
- Motor-Code E/A 1, LS-hinter KAT - Diagnose aus
English
- Engine code I / O 1, Oxygen Sensor - Post CAT - Diagnostics On
- Engine code I / O 1, Oxygen Sensor - Post CAT - Diagnostics Off
0184
German
- Motor-Code E/A 1, Tankdrucksensor-Diagnose ein
- Motor-Code E/A 1, Tankdrucksensor-Diagnose aus
English
- Engine code I / O 1, Tank Pressure Sensor Diagnostics - On
- Engine code I / O 1, Tank Pressure Sensor Diagnostics - Off
0186
German
- EKP2 Diagnose ein
- EKP2 Diagnose aus
English
- EKP2 (Electric Fuel Pump) Diagnostics - On
0188
German
- Motor-Code E/A 1, AAV-Diagnose ein
- Motor-Code E/A 1, AAV-Diagnose aus
English
- Engine code I / O 1, AAV (Activated Charcoal Filter Shutt-off Valve) - Diagnostics On
- Engine code I / O 1, AAV (Activated Charcoal Filter Shutt-off Valve) - Diagnostics Off
0190
German
- Motor-Code E/A 1, permanenter Klimakompressor vorhanden
- Motor-Code E/A 1, permanenter Klimakompressor nicht vorhanden
English
- Engine code I / O 1, Permanent Air Compressor (air conditioning) Exists
- Engine code I / O 1, Permanent Air Compressor (air conditioning) Does Not Exist
0192
German
- Motor-Code E/A 2, Kochschutz ein
- Motor-Code E/A 2, Kochschutz aus
English
- Engine code I / O 2, Boiling (overheat) Protection - On
- Engine code I / O 2, Boiling (overheat) Protection - Off
0194
German
- Motor-Code E/A 2, Adaptive Antriebsdynamik (AAD) ein
- Motor-Code E/A 2, Adaptive Antriebsdynamik (AAD) aus
English
- Engine code I / O 2, Adaptive Drive Dynamics (AAD) - On
- Engine code I / O 2, Adaptive Drive Dynamics (AAD) - Off
0196
German
- M155 nein
- M155 ja
English
- M155 - No
- M155 - Yes
0198
German
- Motor-Code E/A 2, Crash-Signal ueber HW-Leitung, Various Options Listed
English
- Engine code I / O 2, Crash signal
0200
German
- Motor-Code E/A 2, Automatikstart ein
- Motor-Code E/A 2, Automatikstart aus
English
- Engine code I / O 2, Starter Control (Touch Start) - On
- Engine code I / O 2, Starter Control (Touch Start) - Off
0202
German
- Motor-Code E/A 2, var Geschw begrenzer ein
- Motor-Code E/A 2, var Geschw begrenzer aus
English
- Engine code I / O 2, Speedtronic - On
- Engine code I / O 2, Speedtronic - Off
0204
German
- Dashpot ein
- Dashpot aus
English
- Dashpot (Vacuum Canister?) - On
- Dashpot (Vacuum Canister?) - Off
0206
German
- Motor-Code E/A 2, Zylinderabschaltung ein
- Motor-Code E/A 2, Zylinderabschaltung aus
English
- Engine code I / O 2, Cylinder shut off (ACC) - On
- Engine code I / O 2, Cylinder shut off (ACC) - Off
0208
German
- Funktions - Code, KFRTV.0 ein
- Funktions - Code, KFRTV.0 aus
English
- Function – Code, KFRTV.0 On
- Function – Code, KFRTV.0 Off
0210
German
- Funktions - Code, Lambdaregler ein
- Funktions - Code, Lambdaregler aus
English
- Function – Code, Lambda Controller On
- Function – Code, Lambda Controller Off
0212
German
- KlimaKompressor Abschaltung erlaubt
- KlimaKompressor Abschaltung nicht erlaubt
English
- Air compressor (Air Conditioning) shut not - Allowed
- Air compressor (Air Conditioning) shut not - Not Allowed
0214
German
- Kickdown ein Hardware (Schalter)
- Kickdown aus Hardware (Schalter)
English
- Kickdown Switch - On
- Kickdown Switch - Off
0216
German
- Funktions - Code, KFRTV.1 ein
- Funktions - Code, KFRTV.1 aus
English
- Function - Code, KFRTV.1 On
- Function - Code, KFRTV.1 Off
0218
German - Kennfeldauswahl Nachkatsonden, Various Options Listed
English - Post Cat Probe Selection Map Type – Various Options
0220
German - Funktions - Code, KFLF0 Gemischkennfeld TL, Various Options Listed
English - Function Code KFLF0 Mixture Map TL – Various Options
0224
German - Fahrzeug - Code, Vmax = 250 km/h, Various Options Listed
English - Vehicle Code - Speed Limiter = 250 km / h
0232
German
- Fahrzeug - Code, Nsoll-Umschaltung ein
- Fahrzeug - Code, Nsoll-Umschaltung aus
English
- Vehicle Code – N-Set Switching - On
- Vehicle Code – N-Set Switching - Off
0234
German
- Fahrzeug - Code, Allrad vorhanden
- Fahrzeug - Code, Allrad nicht vorhanden
English
- Vehicle Code - All-wheel – Available
- Vehicle Code - All-wheel – Not Available
0236
German - Fahrzeug - Code, Getriebeausstattung = Various Options Listed
English - Vehicle Code - Transmission Equipment = Various Options
0244
German
- Abgas - Code, max. Einschaltdauer Sekundaerluftpumpe = Various Options Listed
English
- Exhaust Cose - Max Duty cycle Secondary air pump (Pollutant std.) = Various Options
0248
German
- Abgas - Code, ULEV ein
- Abgas - Code, ULEV aus
English
- Exhaust Code - ULEV - On
- Exhaust Code - ULEV - Off
0250
German
- Abgas - Code, Regenerierung geregelt ein
- Abgas - Code, Regenerierung geregelt aus
English
- Exhaust Code – Controlled Regeneration (Purge Control Catalytic Converter Particulate) - On
- Exhaust Code – Controlled Regeneration (Purge Control Catalytic Converter Particulate) - Off
0252
German - Abgas - Code, Abgaszyklus = Various Options Listed
English - Exhaust Code – Exhaust Cycle = Various Options
0254
German - Abgas - Code, Lecktest 0 = Various Options Listed
English - Exhaust Code – Fuel Tank Leak Test = Various Options
0256
German
- Abgas - Code, Euro-OBD ein
- Abgas - Code, Euro-OBD aus
English
- Exhaust Code – Euro – OBD = On
- Exhaust Code – Euro – OBD = Off
0258
German
- Abgas - Code, OBD 2 ein
- Abgas - Code, OBD 2 aus
English
- Exhaust Code – OBD2 = On
- Exhaust Code – OBD2 = Off
0260
German
- Bandende, ROZ-Korrektur ein
- Bandende, ROZ-Korrektur aus
English
- RON/ROZ Correction (Fuel Type Certification) - On
- RON/ROZ Correction (Fuel Type Certification) - Off
0262
German
- Bandende, MKV-Korrektur ein
- Bandende, MKV-Korrektur aus
English
- MKV Quantity Corr. - (Multiplicative map adjustment, or Fuel ratio mixture) - On
- MKV Quantity Corr. - (Multiplicative map adjustment, or Fuel ratio mixture) - Off
0264
German
- Bandende, Verzugszeit-Korrektur ein
- Bandende, Verzugszeit-Korrektur aus
English
- Delay time correction - On
- Delay time correction - Off
0266
German
- Bandende, Nsoll-Korrektur, P/N ein
- Bandende, Nsoll-Korrektur, P/N aus
English
- Correction of specified idle speed in selector lever position P or N = On
- Correction of specified idle speed in selector lever position P or N = Off
0268
German
- Bandende, Nsoll-Korrektur, Drive ein
- Bandende, Nsoll-Korrektur, Drive aus
English
- Correction of specified idle speed with drive position engaged = On
- Correction of specified idle speed with drive position engaged = Off
0270
German
- Bandende, CO-Korrektur ein
- Bandende, CO-Korrektur aus
English
- CO Correction - On
- CO Correction - Off
0272
German
- Bandende, Laufunruhe-Korrektur ein
- Bandende, Laufunruhe-Korrektur aus
English
- Rough Running Correction - On
- Rough Running Correction - Off
0274
German
- Bandende, kein ART (Tempomat aktiv)
English
- ART - DTR (active cruise control) – Active
- ART - DTR (active cruise control) – Not Active
0276
German
- Hinterachsuebersetzung = Various Options Listed
English
- Rear Axle Ratio = Various Options
0309
German - 400/600/850 W EC Luefter Bosch/Temic - Various Options Listed
English - EC Fan Type - Various Options - check this
0317
German
- Luftregelsystem (LRS) vorhanden
- Luftregelsystem (LRS) nicht vorhanden
English
- Air control system (LRS) = Available
- Air control system (LRS) = Not Available
0330
German - Kennfelder, tl-Signal Pulsationskennfeld Index 0 (AMG) - Various Options Listed
English - Pulsation compensation of load detection - Various Options
0332
German
- Lambdasondenalterung: Last-/Drehzahlschwelle fuer
Periodendauerueberwachung Variante - Various Options Listed
English
- Lambda sensor aging: Last-/ Speed Threshold for monitoring cycle time variant - Various Options Listed
0334
German
- Datensatz 2 - Various Options Listed
English
- Data Set - Various Options
0338
German
- Lastschlagdaempfung über Luftpfad ein
- Lastschlagdaempfung über Luftpfad aus
English
- Load jerk damping – On
- Load jerk damping – Off
0340
German
- Lastschlag über Zündung (ARMD) – ein
- Lastschlag über Zündung (ARMD) - aus
English
- Load jerk damping - On
- Load jerk damping - Off
0342
German - Pedalkennlinie - Various Options Listed
English - Accelkerator Pedal Characteristic - Various Options
0346
German
- Lüfter Nachlauf aktiv
- Lüfter Nachlauf nicht aktiv
English
- Delayed Fan Switch – Active
- Delayed Fan Switch – not active
0348
German
- Klimaanlage - vorhanden
- Klimaanlage - nicht vorhanden
English
- Air conditioning - available
- Air conditioning - not available
0350
German
- Reserve (0)
- Reserve (1)
English
- Reserve (0)
- Reserve (1)
0352
German
- TEV von Freudenberg verbaut
- TEV5 verbaut
English
- TEV (Thermostatic expansion valve) by Freudenberg – installed
- TEV5 (Thermostatic expansion valve) – installed
