Old Dec 20, 2011 | 12:43 AM
Valk
Default Re: 2005 Crossfire gas pedal isn't accelerating
This might work but your problem sounds a little unusual......
Theory is the ECU adaptively learns your driving style.
This procedure resets it to learn mode so you can teach it to be more aggressive.
Throttle Body Reset
1. Get in your car
2. Turn the key to the on (not start) position, the position just before the starter
turns over.
3. Press the gas pedal to the floor with the key in the "on" position.
4. Hold the pedal to the floor for five seconds, then turn the key back
to the "off" position (don't remove the key), then release the gas
pedal.
5. Wait 2 mins. for a full alignment.
6. Drive the car as you always do.
