Re: Need Belt/Pulley Help
Pulley issue, the bolt is broken or unscrewed. I assume it's the OEM pulley?
Is the bolt still there? Maybe the rubber damper is sheared though instead but ........
Yes I believe it's actually the original and the bolt is still there. Are you supposed to have room to stick your pinky finger in the bolt? Having driven several of the C32's, it does not appear to have been modified with a larger crank pulley. Next question..........where to buy stock OEM crank pulley? Anyone know of a good place besides the "stealer"?
