Old Dec 26, 2011 | 06:02 PM
latemodel21's Avatar
latemodel21
Default Re: Stacked pulleys - 23psi with no codes. :)
Title said it all. My math must have been off a bit, so taking 5.08mm off the stock pulley actually added a full 3psi, when I was shooting for only a 2psi increase.
I was going for 22psi max thinking that anything over that would cause the dreaded over-boost code, but so far it hasn't surfaced. It's obviously too early to celebrate, but I'm cautiously optimistic.
Merry Christmas guys and gals.
Anthony,
did you do your math based on adding 2 psi to the 34.7 psi your supercharge had been moving (ambient air pressure plus your current boost) or adding it to 20psi? (wrong way) . Not saying you did, but many people forget to factor in the ambient air pressure (14.7) and in doing so, add more boost than they intended with pulley changes.
looking forward to seeing what you find as you explore the frontiers for us : )
Chris
