Old Dec 26, 2011 | 06:29 PM
amx1397
Default Re: Stacked pulleys - 23psi with no codes. :)
In all these post no one has ask about the ARF's ,,,,,,,I hope you have a air fuel ratio gauge,, if no, there is a spare engine on e bay you may need it . if you AFR is at wot higher than 13.2 in about 50 runs ,,you will need that engine.,,,,and do you have enough fuel to support both pulleys?
please post your AFR. !!
jim
