Originally Posted by amx1397
In all these post no one has ask about the ARF's ,,,,,,,I hope you have a air fuel ratio gauge,, if no, there is a spare engine on e bay you may need it . if you AFR is at wot higher than 13.2 in about 50 runs ,,you will need that engine.,,,,
and do you have enough fuel to support both pulleys?
please post your AFR. !!
jim
For someone that posts as much as you, you don't seem to read much at all. You must have missed all my threads on running lean, solving it with a SL55 fuel pump, and how correcting the A/F netted me a 5mph increase in trap speed. I'm just a newb, so you probably don't read my threads.
I haven't data logged yet, as I'm letting it get broken in. A quick glimpse of the A/F at WOT showed a range from 11-13 A/f. I'll datalog once the car makes open loop adjustments based on closed loop trims.
